Amazon Alexa as Door Announcer
 Will do. Just trying to get some type of chime notification etc when a door is opened.  Basic function on an alarm system but I can't figure it out on konnected.  Sure there has to be something simple thanks!
Carey,
I initially could not get Alexa to work with my konnected stuff but after I disconnected and reconnected smartthings it was able to work.
Anybody try this since the latest Konnected Firmware update? I added a new contact sensor to Konnected, set it up in Smartthings, discovered it in Alexa. All good to this point, however; if I create a routine in alexa with the new contact sensor it does not work. Even created an Alexa virtual switch that changed state when the contact sensor was pressed and held the state for 5 seconds, in case it was a momentary push problem. Still no luck. Just to be sure I created a routine with an old contact sensor. No problems. Any help would be appreciated.
Have you logged in and out of the Alexa Skill in SmartThings? Or was it the SmartThings Skill in Alexa? One of those you need to log out of and log back in to get routines to work right. Otherwise it will act like it works, but just won't.
