Hardware version 1.8. One of the $79 “steals”. Yes using Home Assistant. Ah - thanks for the clarification for ESPHome. I had wifi working fine previously, but am now trying to move to ethernet, with the updated firmware.
If the firmware has updated successfully it should just connect automatically when Ethernet is plugged in. Contact us at help@konnected.io if you still need help. Providing logs via the USB cable is always helpful to debug (but not for this long thread).
Does the made for ESPHome build from http://install.konnected.io/ include the new firmware to fix the same ethernet problem on the 1.7 hardware revision pro boards? I re-flashed the 1.7 version from the installer and it doesn’t fix the issue. I installed the updated original Konnected firmware as well and the logs show it detecting Ethernet and disabling Wi-Fi, but then cycling in a loop turning Wi-Fi back on and off again.
My Ethernet worked perfectly for 6 months and then died. POE still works and I had to flash it as a Wi-Fi ESPHome version to make it work again.
The Pro v1.7 is not affected by the issue discussed in this thread. The root cause of the issue is related to the RTL8201 chip which is only present in v1.8 (and the upcoming v1.9).
Whatever issue you are having with the v1.7 must be different and unrelated.
For those of us who have avoided placing new orders to give you a bit of breathing space while you sort this out, is now a good time to place the order or should we hold off for another few weeks while you clear the backlog?
The sooner you put your order in, the sooner it will ship. We process orders in the order received. I’m expecting that by the end of this weekend we will have all back-orders processed and shipped.
I just want to say Thank You - for getting a firmware update out that gives us “liquidation” buyers the full functionality and being so transparent. This is my 2nd pro - I paid full for the first one but just needed a couple more zones, so I took a chance and it worked out perfectly!
I will say, at first it seemed like it didn’t work - it was still powering up via POE but never turning on the Ethernet - even after firmware updates - and I was half way through emailing support when I swapped the cable just for good measure, and voila - fired right up… so for others, don’t skip troubleshooting the basics if it doesn’t work the first time!
@Nate, I’m following in your footsteps and struggling with ethernet stability with a custom ESP32 and RTL8201F. Can you share the specific pullup your design lacked that this register write compensates for?
@FirstTracks Yes, the key is pin 12 on the RTL8201F labeled RXD[3]/CLK_CTL. It needs to be pulled high with a 10k resistor to 3.3V to set the REF_CLK to input mode (assuming you’re using an external clock/oscillator like us).
GPIO17 from ESP32 (inverted) clock source. Probably a different issue. Appreciate you sharing the knowledge anyway. I’ll look into the registers to be thorough.
