4-Wire Smoke Detector Reset
Hey all - I've looked through all the pages here and did not see an answer to the question:  Does Konnected reset a 4-wire smoke detector that has been 'tripped'.  With my old DSC panel, once tripped, i pressed *72 to reset the smoke detectors - but I have not seen a similar instruction here.  Help - please.   our should I go to the facebook page (but I couldn't find an existing answer there either when i looked)
I was able to accomplish this by running the power to the smoke detectors through a 5V relay.   Wire Konnected AUX+ to Relay COM.   Then wire Relay NC to smoke detector +.
Power the relay form Konnected +5V & GND then with Konnected OUT to the Relay IN.    Configure ALARM/OUT in SmartThings as a Momentary Switch.   Activating this switch will momentarily disconnect power the smoke detectors resulting in a reset.
 That worked for me - thanks for your help.
So I know this is an older post but I used this setup for my glass break detectors and it seemed to work until the relay at random intervals just resets. This was fun in the middle of the night with the alarm going off. Any ideas? Maybe a bad relay?
