16ohm Internal Sounder in Konnected?
My legacy alarm has an “internal sounder” wired separately to the main alarm siren that “delivers an audio signal to up to 3x 16ohm speakers”. This serves two functions - a loud siren on trigger and quieter warning tones during exit and entry states.
It is unclear what voltage is supplied to this speaker.
Is it possible to use this speaker with Konnected? How would I get the two volumes? Is the best that can be done just an on/off with the alarm terminals?
I pulled out the multimeter and found the following:
  1. When making a “quiet warning”, the voltage supplied is around 0.5v.
  2. When making a “loud alarm”, the voltage supplied is around 2v.
Is it fair to conclude that the volume is driven by voltage?
Given the complexity I will use the supplied piezo buzzer for the “quiet warnings”.
What would be the best way to incorporate this internal speaker to sound with the external siren? I believe it’s just on/off so it would ideally be connected to a switchable output (unfortunately I’ll be using both ALRM terminals already for the external siren and strobe respectively, so I think that counts OUT2 out?).
(a possible solution includes getting a new siren a la UK siren options?)
Typically a sounder with specifications in ohms is just a speaker – it doesn’t make a sound by just applying voltage to it, like the more modern sirens do. A speaker needs a siren driver to create the oscillating sound. You can probably find a siren driver for $10~$20 on Amazon or eBay or something. Basically the siren driver takes a 12V input and outputs the oscillating sound to the siren.
Modern alarm systems sirens have all of that built-in to the logic board inside of the siren, which IMO is way easier to work with. Cost-wise, it’s not usually cost effective to buy a siren driver when you can just replace the whole siren for a more modern one at nearly the same cost.
Yes - I quickly came to the same conclusion after falling into the rabbit hole of speaker power :). I also realised that speakers of this type require AC anyway so yes, a new siren is where I’ve landed. It’ll probably be wired in parallel with the external siren so I can switch the strobe separately.
Hi all,
I’m based in the UK and I’m converting a legacy Honeywell Accenta G3 panel over to a Konnected Alarm Panel Pro (12-Zone Conversion Kit), keeping all the existing wired zones, PA, and the external bell box (Texecom Odyssey 3X).
I’ve found the existing thread on using a siren driver to replicate a loud internal alarm tone through the legacy 16ohm internal speakers ( 16ohm Internal Sounder in Konnected? ) — that makes sense for the main alarm tone.
However, my current panel’s SPEAKER output does more than just the loud alarm tone. It’s a proper internal audio amp circuit (with its own fuse and volume control) that plays several distinct tones through the same speakers depending on the situation:
  • A quiet entry/exit “chime” tone (low volume, day-to-day)
  • The loud full intruder alarm tone
  • Distinct fault/tamper tones
A basic siren driver seems like it would only replicate the single loud alarm tone, not the quieter everyday entry/exit chime through the same physical speakers.
Has anyone found a way to replicate a distinct, quieter chime tone (separate from the main alarm tone) through legacy wired speakers using Konnected outputs? Or is the general consensus that this specific piece is better handled in software — e.g. triggering a chime sound through Home Assistant/Alarmo via existing smart speakers — rather than through the original speaker wiring?
Would appreciate any pointers from anyone who’s solved this on a similar legacy panel conversion.
Thanks!
Matt
Hi!
Not sure what more to add to this thread:
  1. Bin the existing speaker
  2. Use the provided piezo buzzer for warnings and chimes
  3. Acquire a new 5v sounder (for ~£3 via aliexpress/ebay) for the intruder alarm
The Pro board has enough outputs to control the piezo, sounder and bellbox separately (although you may need some bespoke switching logic to turn the 5v sounder on and off).
