Noticed two specific zones configured ad binary sensors from 6-Zone Konnected Alarm Panels, keep ON permanently after first motion detection. Tried with following work around, but have no success:
Flashed device and reinstall ESPhome few times
Adjust potentiometer of panel interface and verified that turn off when motion is detected
In Alarm Panel web view, noticed zone is detected from ON to OFF first time (after uploading software) but zone keep ON and not new detection is displayed.
Exchanged terminals in panel interface to ensure issue is not caused by sensor from different zone.
YAML configuration is by default and validation did not show any error.
Any help to test in different way to discover the issue?
Hi. Yes. I’m using Interfase module with DSC alarm board. I adjusted LED (off/on according instruction) but only this two zones changed first time when module is reseted. After first detection, amber LED keep on forever. Tested same zones in alarm panel and lights indicators works every detection and alarm siren also works…I didn’t try to connect zone in question directly to 6 zone Konnected alarm module. Any problem or need to remove uplink cable between boards? Thanks
I really don’t know what would be causing that problem. Are you saying it is only not working on Zone 3? If you move the same wires to a different zone does it work properly? It could be a hardware component failure if the problem is only present on one zone.
Otherwise I would suspect something in the wiring of the sensor or panel.
