Dear Mike.
Great new 1.1.0 version, thanks!
I was able to activate the new alarmsystem via Homebridge and everything works fine, except the trigger of the siren via my Wave-2.
The config I use is the following with one of my V2 PRO panels:
"enabled": true,
"zoneNumber": "alarm1",
"zoneType": "siren",
"zoneLocation": "Hallway",
"switchSettings": {
"trigger": "high"
}In debug mode, I see the following:
"endpoint_type": "rest",
"endpoint": "http://192.168.1.205:52623/api/konnected",
"token": "xxx-xxx-xxx",
"blink": true,
"discovery": true,
"platform": "Homebridge",
"sensors": [],
"dht_sensors": [],
"ds18b20_sensors": [],
"actuators": [
"zone": "alarm1",
"trigger": 1
}Even if I change the state of the switch in Homekit or Homebridge, there is no sound.
When I change the trigger from 'high' to 'low', the siren sounds loud but I can not let it stop or use the switch in Homekit or Homebridge.
I'm running the latest software and firmware on my panels.
Do you have some advice please?
Best regards and keep up the good work,
Mathieu.
