Error doing job: Future exception was never retrieved
File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run
result = self.fn(*self.args, **self.kwargs)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/konnected/__init__.py", line 131, in device_discovered
setup_device(host, port)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/konnected/__init__.py", line 121, in setup_device
discovered.setup()
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/konnected/__init__.py", line 284, in setup
self.sync_device_config()
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/konnected/__init__.py", line 388, in sync_device_config
if self.desired_settings_payload() != self.current_settings_payload():
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/konnected/__init__.py", line 368, in current_settings_payload
settings = self.status['settings']
KeyError: 'settings'
Is there any way to update the firmware remote/over the air or do you have to remove them to do it or plug a cable in? For what its worth mine are stuck in my old alarm box with the double side tape that came with them so updating can be done but its a pain.
You can simply pull out the WiFi module and bring it to your computer. Leave the Konnected board and wiring mounted and intact. Just disconnect the power before you do this.
