Toggle in Home Assistant?
In the ESPHome interface and Home Assistant I see there is a switch to “turn on” Toggle Only. What is that supposed to mean? I don’t see a “Toggle” motion button and the Up, Down, and Stop buttons appear to perform their normal function when Toggle Only is on. I’m probably missing the obvious.
For my needs this is SOLVED. I created the following Automation in Home Assistant that implements the Toggle action for a Cover. In Home Assistant I also see an entity called Wall Button which I assumed would emulate a wall button but that doesn’t appear to be the case.
