I have seen the other threads on recent problems with switches, am not sure whether this is related.
I am on HA 0.90.0, latest konnected firmware. I do not have multiplying switches. My switches work reliably when invoked manually, but only rarely when invoked from an automation.
I have the following errors in my log many times. Reading to the bottom, it does indicate a problem in the konnected switch code (switch.py line 75).
I'm hesitant to upgrade HA due to the other switch related issues I've seen reported. Are those considered fully resolved, and does this seem related?
Error doing job: Task exception was never retrieved
File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 384, in _make_request
six.raise_from(e, None)
File "<string>", line 2, in raise_from
File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 380, in _make_request
httplib_response = conn.getresponse()
File "/usr/lib/python3.5/http/client.py", line 1198, in getresponse
response.begin()
File "/usr/lib/python3.5/http/client.py", line 297, in begin
version, status, reason = self._read_status()
File "/usr/lib/python3.5/http/client.py", line 258, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/lib/python3.5/socket.py", line 576, in readinto
return self._sock.recv_into(b)
ConnectionResetError: [Errno 104] Connection reset by peer
During handling of the above exception, another exception occurred:
File “/srv/homeassistant/lib/python3.5/site-packages/requests/adapters.py”, line 449, in send
timeout=timeout
File “/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py”, line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File “/srv/homeassistant/lib/python3.5/site-packages/urllib3/util/retry.py”, line 367, in increment
raise six.reraise(type(error), error, _stacktrace)
File “/srv/homeassistant/lib/python3.5/site-packages/urllib3/packages/six.py”, line 685, in reraise
raise value.with_traceback(tb)
File “/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py”, line 600, in urlopen
chunked=chunked)
File “/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py”, line 384, in _make_request
File “<string>”, line 2, in raise_from
File “/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py”, line 380, in _make_request
File “/usr/lib/python3.5/http/client.py”, line 1198, in getresponse
response.begin()
File “/usr/lib/python3.5/http/client.py”, line 297, in begin
File “/usr/lib/python3.5/http/client.py”, line 258, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), “iso-8859-1”)
File “/usr/lib/python3.5/socket.py”, line 576, in readinto
urllib3.exceptions.ProtocolError: (‘Connection aborted.’, ConnectionResetError(104, ‘Connection reset by peer’))
File “/srv/homeassistant/lib/python3.5/site-packages/konnected/init.py”, line 57, in put_device
r = requests.put(url, json=payload, timeout=10)
File “/srv/homeassistant/lib/python3.5/site-packages/requests/api.py”, line 131, in put
return request(‘put’, url, data=data, **kwargs)
File “/srv/homeassistant/lib/python3.5/site-packages/requests/api.py”, line 60, in request
return session.request(method=method, url=url, **kwargs)
File “/srv/homeassistant/lib/python3.5/site-packages/requests/sessions.py”, line 533, in request
resp = self.send(prep, **send_kwargs)
File “/srv/homeassistant/lib/python3.5/site-packages/requests/sessions.py”, line 646, in send
r = adapter.send(request, **kwargs)
File “/srv/homeassistant/lib/python3.5/site-packages/requests/adapters.py”, line 498, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: (‘Connection aborted.’, ConnectionResetError(104, ‘Connection reset by peer’))
File “/usr/lib/python3.5/asyncio/tasks.py”, line 241, in _step
result = coro.throw(exc)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/core.py”, line 1138, in async_call
self._execute_service(handler, service_call))
File “/usr/lib/python3.5/asyncio/futures.py”, line 380, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.5/asyncio/tasks.py”, line 304, in _wakeup
future.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
raise self._exception
File “/usr/lib/python3.5/asyncio/tasks.py”, line 239, in _step
result = coro.send(None)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/core.py”, line 1160, in _execute_service
await handler.func(service_call)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_component.py”, line 188, in handle_service
self._platforms.values(), func, call, service_name
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/service.py”, line 314, in entity_service_call
future.result() # pop exception if have
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/service.py”, line 328, in _handle_service_platform_call
await getattr(entity, func)(**data)
future.result()
File “/usr/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
result = self.fn(*self.args, **self.kwargs)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/konnected/switch.py”, line 75, in turn_on
self._pause
File “/srv/homeassistant/lib/python3.5/site-packages/konnected/init.py”, line 60, in put_device
raise Client.ClientError(err)
konnected.Client.ClientError: (‘Connection aborted.’, ConnectionResetError(104, ‘Connection reset by peer’))
