Hello meanwhile waiting for the final PR approve I wanted to play a bit with my device and I have installed a brand new Hassbian installation (68.1) and upgraded with the konnected git source with the procedure describe on the website. My konnected device is connected to wifi ( I see it on my router) I have wired one zone and im trying to test it with home assistant. here is my configuration.yaml :
konnected:
auth_token: adsd78sj3wsa2g3
devices:
- id: fdf2b1
binary_sensors:
- zone: 1
type: door
I see the door icon on the top of HA main panel, but I have an error in the log :
Any idea, thank you ?
Log Details (ERROR)
Tue May 08 2018 19:15:58 GMT-0400 (Eastern Daylight Time)
Error handling request
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 381, in start
resp = await self._request_handler(request)
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/web_app.py", line 322, in _handle
resp = await handler(request)
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/web_middlewares.py", line 88, in impl
return await handler(request)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/http/static.py", line 68, in staticresource_middleware
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/http/real_ip.py", line 27, in real_ip_middleware
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/http/ban.py", line 68, in ban_middleware
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/http/auth.py", line 28, in auth_middleware
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/http/view.py", line 104, in handle
result = await result
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/konnected.py", line 279, in put
payload = await request.json()
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/web_request.py", line 537, in json
return loads(body)
File "/usr/lib/python3.6/json/__init__.py", line 354, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.6/json/decoder.py", line 339, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.6/json/decoder.py", line 357, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
