“Open” & “Closed” entries on history logs
Hello,
Looking for some info. New to Konnected, but long time ST user. I had been waiting for a ESP32 solution that ran locally but gave up and purchased the GDO blaQ. I got it connected and running with a few routines. So far so good!
The other day I was reviewing the history logs in ST when I noticed a handful of the main, door “open” and “closed entries. With none of these time was the garage door opened or closed. I do see in the log where the call to open or closed the door it has a main, door “Opening” or “Closing” entry. What is causing these entries and should I be concerned?
Thank you in advanced for your support.
This is probably caused by the device rebooting periodically. This has been mostly fixed in firmware version 1.3.3.x, so make sure your firmware is up to date if not already.
Also, if you are using SmartThings only and not Home Assistant or Hubitat, make sure to disable the Local Native API in the settings – this is not needed for SmartThings and this is what causes it to reboot periodically if no local native client is connected.
I was on firmware 1.3.3.4 so I reran the configuration with ver 1.3.3.5 and disabled the Local Native API. I will monitor the logs to see if it still reboots.
After making the recommended changes I have been checking the ST history logs and it appears to have corrected the reboots. No more random open or closed entries. Thank you.
