I would really appreciate any help that you could provide me with setting up the relay to act as a 'key switch'
I am trying to understand if ...
Should the really be Normally Open or Normally Closed ?
Do you keep the realay open or closed for the period you want it alarmed or should it be used as a momentary switch ?
Is a resistor needed in the wiring, what value and series or parallel ?
