A new year…, time to install my new Alarm Panel Pro. Took bunch of pictures of the ~25yr old Galaxy with lots of history you can tell. All sensors still working. But when converting to Konnected I’m running into a snag …
Firmware prepared in the app, SmartThings + Home Assistant work and show the different doors/windows.
To start simple, I’m just connecting the zones only and copying from the old Galaxy as much as possible. (leaving the siren and buzzer for later). On the Galaxy some wires had extra resistors, some connect to 2 ports (?). I don’t know what that all means, but I’ve cut the resistors where applicable.
Now, Zones 4,5,8 are working and respond to open/ close of the doors.
Zones 1,2,7 are not working and show “OFF” (closed) - but don’t respond to open / close of the door.
The easiest to verify are the zones 1 + 2, I’m identically copying zone 1 + 2 from the old Galaxy to the Konnected 1-to-1. No resistors removed, both connect the yellow wire to the GND, both are simple door sensor. I’ve re-stripped them, reconnected …
I’ve tried swapping Z1 <> G, swapping the wires connecting Z7 and Z8
Now what I also notice, the working zones are connecting with the familiar, visible on-door magnets. The non-working zones are connecting the invisible RC-33. Coincidence?
How do I best troubleshoot this? What things can I check / anything a multimeter will solve?
