New Product: DC to USB-C Power Delivery Fast Charging Converter
Hey everyone,
We’re excited to announce a new accessory that many of you have been asking for! The Konnected DC to USB-C Power Delivery (USB-PD) Fast Charging Converter.
USB-CONV-PD-TYPEC-S main
If you’ve been using our 12V to 5V USB Power Converter to power a tablet or Raspberry Pi from your alarm panel, this one’s for you.
Why we built this
Our original 5V USB converter has been one of our most popular accessories, and for good reason — it solves a real problem. But we kept hearing the same feedback: modern tablets, Fire tablets, and especially the Raspberry Pi 5 don’t power reliably (or at all) from a plain 5V USB port. iPads in particular will display “Not Charging” or charge at a trickle unless they get a proper USB-PD handshake at a higher voltage.
The new USB-PD converter fixes that. Instead of outputting a fixed 5V, it negotiates voltage with your device automatically — delivering 5V, 9V, 12V, 15V, or 20V depending on what’s needed, up to 65W total. No configuration, no fiddling. Plug in your device and it just works at full speed.
What’s new vs. the 5V converter
12V to 5V USB Converter USB-PD Converter (new)
Output voltage Fixed 5V 5V / 9V / 12V / 15V / 20V (auto)
Max output power 15W 65W
Fast charging No Yes — PD 3.0, QC 3.0, and more
iPad / Fire tablet full-speed charging No Yes
Input voltage range 8V - 23V DC 10V - 30V DC
Output connector USB-C USB-C
Use cases
  • Wall-mounted tablet — wire it to your alarm panel’s 12V aux terminals and keep an iPad or Fire tablet charged 24/7 without a wall outlet
  • Vehicle hardwire — permanently install a USB-C fast charger in your car, truck, RV, or boat without an ugly plug-in adapter
  • Solar setups — connect to a charge controller’s aux output and run USB-C loads from your battery bank
Specs at a glance
  • Input: 10–30V DC (bare wire leads)
  • Output: up to 65W via USB-C (auto-negotiated PD)
  • Protocols: USB PD 3.0/2.0, PPS, QC 3.0/2.0, AFC, FCP, Apple, Samsung
  • Reverse polarity protected, overcurrent protected, short-circuit protected
  • Operating temp: -20°C to 60°C
  • Price: $22.95
Available now on konnected.io and Amazon.
As always, let us know how you’re using it — we love seeing your install photos and setups. And if you run into any questions wiring it up, drop them below.
Hi, when is this likely to be back in stock?
There are already more delivered to Amazon, just waiting on Amazon to check them in and make them available for sale. We never know how long this takes. Sometimes it’s a day or two, sometimes weeks.
We have a few in stock now at Konnected HQ if you order directly on konnected.io.
