New to this stuff, but looking to add this to the house I am building. I would like to have wired sensors and be able to access them all on my Hubitat hub. The Konnected board will connect to the Hubitat using Wifi, but it doesn’t require an internet connection, right? Would you connect this with your same SSID that your internet is on, or should I have a separate SSID for konnected?
My main reason for using this over zwave, zigbee sensors is cost and not needing to worry about batteries. Am I on the right track?
