Integration with Universal Devices EISY through a Plug-in
The Eisy has a loyal, tech following. Many homes have older alarm panels that people would like to integrate into their EISY. Same with garage door openers. Developers, through open APIs write Plug-ins for (over 100 exist), for the EISY.
Currently RATDGO is supported, but no Konnected products.
This is big potential for many people that are not on a Smartthings platform to use your products, which are awesome.
Here is a link to the many plug ins avaialbe.: Polyglot v3 (PG3x) - Universal Devices Forum
Would love to see Konnected there too!
The Ratgdo plugin might work with Konnected’s GDO blaQ out of the box. Both products are using the ESPHome framework and use the HTTPS/Events API provided by ESPHome.
I’m happy to support any developers who wish to adapt a plugin for this platform.
Thanks… I actually sent a blaq to the developer of the RATDGO plugin and he said that it was going to be a bit of work because while the structure is the same, all the names are different so he “passed” on it and sent it back to me.
I have two homes. One uses Smartthings, so I installed it there. Works FABULOUSLY. Super easy. I also have two of your security panels here.
At the other home, I use an EISY from Universal devices and have two RATGOs on my pole barn.
Am looking to put Konnected on my 3 house garage doors, but it needs to integrate with my EISY.
Lastly, as one of your STARTENGINE early investors, I would love to see the Konnected security panel with a plug in as well as I think there is market for that in this group, but not sure.
I can put you in touch with the RATGDO plug in developer if you would like?
Let me know privately. Thanks.
If it’s just a matter of naming, it should be pretty straightforward to either rename the entities in the Konnected firmware or rename the keys in the driver code.
I’m happy to advise but unfortunately I do not have the bandwidth to work on this at the moment.
