Implement a self-monitoring alarm system using mainstream products.
Integrate smoke detectors into the alarm system so I would be notified if a smoke detector is activated. Note: Disarming the system does not silence the smoke detectors.
Thanks so much for you diagrams and very details directions. I have things set up the same not including the expansion board or smoke alarm set up. The alarm works as expected when I set the alarm with my phone, but if I set my alarm with the hardwired panel, it does not change status in SmartThings or send notifications, so I can’t control anything from my phone. What connections make that communication work?
