Hi, i am trying to get my system configured before doing the big switch over and i have a few problems/questions
I plan to use a Amazon fire 7 as the control panel just inside the door, some family members will use their phones as present sensors and some will need to use the Tablet to deactivate the alarm.
One of the main problem is adding the entry and exit bleeps ( to keep the wife happy), i have SHM Delay installed and set up, this seem it works fine in Armed away mode giving you time to open and close the door and the same returning. i have installed Webcore to try and create a piston for the bleeps but this is doing my head in can anyone give some assistance please, i am sure it is just a simple bit of coding.
i just want the system to beep for 20 second until the system is armed and then to beep for 20 seconds on returning
The front door has a contact sensor attached, this leads to a small hallway that is covered by a Motion sensor and the tablet is going to be place on the wall in the hallway.
thanks for any help
my main issue is setting a exit/entry bleep on the system like
