I was in the process of installing the Konnected system in conjunction with my traditional NX6-V2 wired alarm system so that I can keep the keypad functionality (and keep it simple for the family).  After days and DAYS of trial and error, I gave up and just replaced the traditional alarm system with the Konnected Alarm Pro system.  I disconnected the keypads, and behind them I wired in the Piezo buzzers to function as door chimes.  This was all fine and dandy, but the problem is that if the system is armed and a door opens (say when I return home from work or let the dog out in the morning), I won't know if the system is armed unless I look at my phone OR hook up a tablet interface.  Neither of these methods though will give an audible alert that the system is armed if a door is opened just as a traditional system would.  It also doesn't give an audible countdown when the system is arming letting you know to get out. From what I've researched online, there's also no way to get the Konnected system to mimic these two traditional system features.
Does anyone know how I can replicate those two features using the Konnected system and Smart Things?
As an FYI, I purchased the Konnected alarm pro board with ethernet port and two interface modules. I'm also using Smart Things. I've dabbled in Home Assistant for home automation but ST was quicker to set up and easier to use so I stuck with that.
