I have three of the very early GDO Whites from when they first went on sale in 2023.
Each reports GDOv1-S in the Hubitat device listing.
Number 1 has become stuck on flashing blue. #2 seems to work. #3 is stupid and can no longer distinguish open or closed and reports/shows nonsense status in my Hubitat dashboard, It is a lying POS.
–> #1 Flashing blue fixed, see below.
Here are the numbers from the Konnected App:
#1 V1.2.5.2 Cal: 0.40M Dist: 0.00 Signal: 78% stuck on Blue flashing, Lying POS on status
Q: How can a TOF sensor measure 0.00 distance?
→ Later - delete device, add device. Blue blink gone. Now wrong door icon in dashboard.
–>Found two GDOv1-S device drivers, unable to delete old one, all 3 now use same one
–> Now like Door #3, Lying POS shows WRONG status in dashboard and device list.
#2 V1.2.5.3 Cal: 0.46m Dist: NA Signal: 54% works for some reason
#3 V1.2.5.4 Cal: 0.44m Dist: 0.04 Signal: 42% lying POS on status, no other problem indication
I don’t know if the ESP updates messed these up (unlikely) or if the newer Hubitat software is part of the problem (but #2 is fine). Hubitat device status shows last activity on each within seconds of each other, yet GDO #1 is shown as having a WiFi issue even though the Konnected App works with it just fine and it seems to report to the Hubitat.
–> Later - WiFi status problem in device list cleared
I know many of you are Home Assistant fan boys. I used it for over year with my Hubitat and the MakerAPI integration. Trashed HA a few months ago as too much trouble to maintain the container version. Had some nice features though.
Don’t want to hear about HA. Thanks.
These things worked great for two years or so with my Hubitat C-8. Now one by one they seem to go bad or crazy. While the Hubitat just gets better and better with software updates.
In any case having a GDO working poorly is worse than having none at all.
Before I rip #1 and #3 out, can they be redeemed?
I hate these things.
Yet, my Konnected Pro alarm panel board has been working fine since 2019.
