App not showing updates for GDO blaQ?
I have two GDO blaQ units that are running Firmware: 1.5.5.2 (ESPHome 2025.11.5). It appears there are newer versions but the app does not offer me the option to install them like it has in the past.
My Alarm Panel Pro is offering to let me upgrade from 1.2.1.2 to 1.2.2. But nothing for the blaQ units.
Tried clearing the data and cache in the app but still no option to upgrade. Would rather not mess with pulling them down to upgrade via USB.
Hi @ThomasB,
You should be able to tap Settings in the Konnected app on each GDO blaQ device, verify your desired firmware settings and configuration, then tap Save & Continue then Build now.
Every time you build a new firmware using this process, it will always get the latest Konnected firmware version and ESPHome platform version.
