Ability to specify access token
Is it possible to specify a specific access token when adding Konnected to Smartthings? I currently have my Konnected system integrated with Home Assistant. I would like to add it to both Konnected and Smart Things. However, when I add Smartthings, it seems to be overwriting the access token and Konnected can no longer communicate with the Konnected board. So, is there a way I can use my access token from Home Assistant when I'm instegrating with Smart Things--maybe by editing the Smartthings Konnected code?
