Does anyone have the water sensor wiring setup?
Ok I cannot get this to work with a remote power supply? The alarm will not trigger an alert… the light comes on sensor but doesn’t trigger alert
Sigh, these sensors have be be completely home run and powered from the panel board or they will not work. you cannot use an independent power source.
