Just received my kit to maintain current alarm system vista 15p and have access to it with an app.
It is not a simple straight forward instructions to that, and I found that when saw on the instructions paper there is two Z6 to connect on the old alarm. And that is not the only contradiction on the instructions I have found around. So, I bought the 6 zones konnected system because my vista 15p is also 6 zones, but now that I am trying to install it found out:
- For vista 15p I will be only able to use 4 zones instead of the 6 it originally have. Z1 is not compatible with konnected, but some of the instructions indicated that I still can use it if I connect a 2000 ohm resistor (what is right?). I need to free a zone so that I can keep using the original keypad (arming the original system). All of this requires not only rewiring but also reprograming.
- Rewire and reprogram to use only 4 zones
- Purchase the 4229 ademco expansion / relay module. and keep my original 6 zones or more. (need to investigate how to wire it and program it.
