I just recently installed my Konnected.io GDO blaQ and adopted it to my Home Assistant server.
This all went smoothly, however my unit is running firmware 1.3.3 and I was wanting to update and possibly modify the firmware, however attempting to install either the ESPHome firmware that was auto-populated, or the garage-door-GDOv2-Q.yaml contents from the github, all fail during compiling.
Both attempts are getting hung up with the same error regarding ./components/secplus_gdo/secplus_gdo.cpp.o:
In file included from src/esphome/components/secplus_gdo/secplus_gdo.h:23,
from src/esphome/components/secplus_gdo/secplus_gdo.cpp:18:
src/esphome/components/secplus_gdo/select/gdo_select.h: In member function 'void esphome::secplus_gdo::GDOSelect::update_state(gdo_protocol_type_t)':
src/esphome/components/secplus_gdo/select/gdo_select.h:42:57: warning: 'esphome::select::Select::state' is deprecated: Use current_option() instead of .state. Will be removed in 2026.5.0 [-Wdeprecated-declarations]
42 | if (this->has_state() && value != this->state) {
In file included from src/esphome/components/secplus_gdo/select/gdo_select.h:10:
src/esphome/components/select/select.h:39:15: note: declared here
39 | std::string state{};
src/esphome/components/secplus_gdo/secplus_gdo.cpp: In lambda function:
src/esphome/components/secplus_gdo/secplus_gdo.cpp:140:50: warning: implicit capture of 'this' via '[=]' is deprecated in C++20 [-Wdeprecated]
140 | this->set_interval("gdo_start", 500, [=]() {
src/esphome/components/secplus_gdo/secplus_gdo.cpp:140:50: note: add explicit 'this' or '*this' capture
src/esphome/components/secplus_gdo/secplus_gdo.cpp: In function 'void __wrap_esp_panic_handler(void*)':
src/esphome/components/secplus_gdo/secplus_gdo.cpp:185:5: error: 'gpio_hal_iomux_func_sel' was not declared in this scope; did you mean 'gpio_hal_func_sel'?
185 | gpio_hal_iomux_func_sel(GPIO_PIN_MUX_REG[(gpio_num_t)GDO_UART_TX_PIN], PIN_FUNC_GPIO);
| gpio_hal_func_sel
*** [.pioenvs/konnected-523294/src/esphome/components/secplus_gdo/secplus_gdo.cpp.o] Error 1
I have tried cleaning build files between install attempts, however this does not change the behavior.
I didn’t see anyone else posting about this, which leads me to think I’m doing something wrong but I’ve got other ESPHome devices that compile / install just fine.
Any help would be greatly appreciated!
Thank you ![]()
