Using the Konnected pro board with two interface modules in parallel with Ademco Vista 15P but having an issue with the keyswitch.
Set Up
-jumper wire with 2k ohm resister is connected from #8 on Ademco board to relay on 2nd interface module.
-jumper wire connected from #9 on Ademco board to relay on 2nd interface module.
-jumper wire connected from Out on 2nd interface module to Out 2 on panel pro.
-jumper is set to NO on 2nd interface module
Error
After programming key pad zone 1 (ZN: 01, ZT: 77, P:1, RC:10 EL:1), panel beeps and reads check zone 1.
