Recently started getting random false alarms etc and siren not going off after updating esphome addon in HA
do i need to update to the latest firmware please (currently at 2024.9.0) using the tool over microusb after going to https://install.konnected.io/ ?
i am getting the following odd errors when i try to update within esphome in HA by clicking on the update tab…
INFO ESPHome 2025.2.2
INFO Reading configuration /config/esphome/konnected-87061b.yaml...
WARNING Found '$zone5' (see substitutions->warning_beep_pin) which looks like a substitution, but 'zone5' was not declared
WARNING Found '$project_name' (see esphome->project->name) which looks like a substitution, but 'project_name' was not declared
WARNING Found '$project_version' (see esphome->project->version) which looks like a substitution, but 'project_version' was not declared
WARNING Found '$zone1' (see binary_sensor->0->pin->number) which looks like a substitution, but 'zone1' was not declared
WARNING Found '$sensor_debounce_time' (see binary_sensor->0->filters->0->delayed_on_off) which looks like a substitution, but 'sensor_debounce_time' was not declared
WARNING Found '$zone2' (see binary_sensor->1->pin->number) which looks like a substitution, but 'zone2' was not declared
WARNING Found '$sensor_debounce_time' (see binary_sensor->1->filters->0->delayed_on_off) which looks like a substitution, but 'sensor_debounce_time' was not declared
WARNING Found '$zone3' (see binary_sensor->2->pin->number) which looks like a substitution, but 'zone3' was not declared
WARNING Found '$sensor_debounce_time' (see binary_sensor->2->filters->0->delayed_on_off) which looks like a substitution, but 'sensor_debounce_time' was not declared
WARNING Found '$zone4' (see binary_sensor->3->pin->number) which looks like a substitution, but 'zone4' was not declared
WARNING Found '$sensor_debounce_time' (see binary_sensor->3->filters->0->delayed_on_off) which looks like a substitution, but 'sensor_debounce_time' was not declared
WARNING Found '$zone6' (see binary_sensor->4->pin->number) which looks like a substitution, but 'zone6' was not declared
WARNING Found '$sensor_debounce_time' (see binary_sensor->4->filters->0->delayed_on_off) which looks like a substitution, but 'sensor_debounce_time' was not declared
WARNING Found '$alarm' (see switch->0->pin->number) which looks like a substitution, but 'alarm' was not declared
WARNING Found '$zone5' (see switch->1->pin) which looks like a substitution, but 'zone5' was not declared
WARNING Found '$blink_on_state' (see globals->0->initial_value) which looks like a substitution, but 'blink_on_state' was not declared
WARNING Found '$status_led' (see light->0->pin->number) which looks like a substitution, but 'status_led' was not declared
WARNING Found '${warning_beep_pulse_time}' (see light->1->effects->0->strobe->colors->0->duration) which looks like a substitution, but 'warning_beep_pulse_time' was not declared
WARNING Found '${warning_beep_pause_time}' (see light->1->effects->0->strobe->colors->1->duration) which looks like a substitution, but 'warning_beep_pause_time' was not declared
WARNING Found '$zone5' (see output->0->pin->number) which looks like a substitution, but 'zone5' was not declared
Failed config
esphome: None
friendly_name: KonnectedPanel
name_add_mac_suffix: False
project:
project name needs to have a namespace.
version: $project_version
on_boot:
- priority: 800.0
then:
- text_sensor.template.publish:
state: !lambda |-
My yaml code is…
substitutions:
warning_beep_pin: $zone5
esphome:
name_add_mac_suffix: false
packages:
remote_package:
url: https://github.com/konnected-io/konnected-esphome
ref: master
refresh: 5min
files:
- packages/core-esp8266.yaml
- packages/alarm-panel/zone1.yaml
- packages/alarm-panel/zone2.yaml
- packages/alarm-panel/zone3.yaml
- packages/alarm-panel/zone4.yaml
- packages/alarm-panel/zone6.yaml
- packages/alarm-panel/alarm.yaml
- packages/wifi.yaml
- packages/status-led.yaml
- packages/warning-beep.yaml
switch:
- platform: gpio
pin: $zone5
api:
encryption:
key: ng8Yr5EAd......
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.30.4
gateway: 192.168.30.1
subnet: 255.255.255.0
dns1: 192.168.30.2
