ESPhome and supplied piezo buzzer
Hi,
Currently the entity “Alarm Panel Warning Beep” activates the main siren
I’ve attached the piezo buzzer to zone 5
How do i “re-assign” this to zone 5 so that i can start using the buzzer in my HA automations please (for example to use for entry exit tones)?
I assume i have to edit the the esphome device yaml file to reassign?
Yes, you will need to edit the YAML for the device. Here’s the github repo:
hmm getting a bit confused here …after reading doc’s i tried following new esphome config …
substitutions:
  friendly_name: KonnectedPanel
packages:
  url: http://github.com/konnected-io/konnected-esphome
  ref: master
  refresh: 5min
  files:
    - packages/alarm-panel-esp8266-base.yaml
    - packages/alarm-panel/zone1.yaml
    - packages/alarm-panel/zone2.yaml
    - packages/alarm-panel/zone3.yaml
    - packages/alarm-panel/zone4.yaml
    - packages/alarm-panel/zone6.yaml
    - packages/alarm-panel/alarm.yaml
    - packages/wifi.yaml
    - packages/warning-beep.yaml
    - packages/status-led.yaml
esphome:
  name_add_mac_suffix: false
switch:
  - platform: gpio
    pin: $zone5
api:
  encryption:
    key: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.30.4
    gateway: 192.168.30.1
    subnet: 255.255.255.0
    dns1: 192.168.30.2
but when i validate before uploading am getting the following error output?
INFO ESPHome 2024.9.2
INFO Reading configuration /config/esphome/konnected-87061b.yaml...
Failed config
packages: [source /config/esphome/konnected-87061b.yaml:6]
  not a valid value.
  not a valid value.
  ref: master
  not a valid value.
  refresh: 5min
  Shorthand only for strings.
  files:
any ideas please?
Assuming you’ve adopted your ESPHome device into ESPHome dashboard in HA, just edit the device configuration and add the following to the substitutions section:
substitutions:
  warning_beep_pin: $zone5
Then, you want to remove zone5 package from the input zones, so your packages section should look like this (notice the zone5 package is removed):
packages:
  remote_package:
    url: https://github.com/konnected-io/konnected-esphome
    ref: master
    refresh: 5min
    files:
      - packages/core-esp8266.yaml
Also note that if managing the YAML files for your firmware is a bit too tedious, we now have the ability to customize this in the Konnected app instead. Just use the Konnected app to discover the device, tap Settings to set up your zones and outputs, and update the firmware via the app. When you do this, you can remove the device config from ESPHome dashboard.
perfect, thanks :slight_smile:
hi, just got round to trying it, but for some reason getting errors…
my code…
substitutions:
esphome:
packages:
  remote_package:
    ref: master
    refresh: 5min
    files:
switch:
  - platform: gpio
    pin: $zone5
api:
  encryption:
    key: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
wifi:
  manual_ip:
    dns1: 192.168.30.2
when validating getting ....
WARNING Found '$zone5' (see substitutions->warning_beep_pin) which looks like a substitution, but 'zone5' was not declared
WARNING Found '$project_name' (see esphome->project->name) which looks like a substitution, but 'project_name' was not declared
WARNING Found '$project_version' (see esphome->project->version) which looks like a substitution, but 'project_version' was not declared
WARNING Found '$zone1' (see binary_sensor->0->pin->number) which looks like a substitution, but 'zone1' was not declared
WARNING Found '$sensor_debounce_time' (see binary_sensor->0->filters->0->delayed_on_off) which looks like a substitution, but 'sensor_debounce_time' was not declared
WARNING Found '$zone2' (see binary_sensor->1->pin->number) which looks like a substitution, but 'zone2' was not declared
WARNING Found '$sensor_debounce_time' (see binary_sensor->1->filters->0->delayed_on_off) which looks like a substitution, but 'sensor_debounce_time' was not declared
WARNING Found '$zone3' (see binary_sensor->2->pin->number) which looks like a substitution, but 'zone3' was not declared
WARNING Found '$sensor_debounce_time' (see binary_sensor->2->filters->0->delayed_on_off) which looks like a substitution, but 'sensor_debounce_time' was not declared
WARNING Found '$zone4' (see binary_sensor->3->pin->number) which looks like a substitution, but 'zone4' was not declared
WARNING Found '$sensor_debounce_time' (see binary_sensor->3->filters->0->delayed_on_off) which looks like a substitution, but 'sensor_debounce_time' was not declared
WARNING Found '$zone6' (see binary_sensor->4->pin->number) which looks like a substitution, but 'zone6' was not declared
WARNING Found '$sensor_debounce_time' (see binary_sensor->4->filters->0->delayed_on_off) which looks like a substitution, but 'sensor_debounce_time' was not declared
WARNING Found '$alarm' (see switch->0->pin->number) which looks like a substitution, but 'alarm' was not declared
WARNING Found '$zone5' (see switch->1->pin) which looks like a substitution, but 'zone5' was not declared
WARNING Found '$blink_on_state' (see globals->0->initial_value) which looks like a substitution, but 'blink_on_state' was not declared
WARNING Found '$status_led' (see light->0->pin->number) which looks like a substitution, but 'status_led' was not declared
WARNING Found '${warning_beep_pulse_time}' (see light->1->effects->0->strobe->colors->0->duration) which looks like a substitution, but 'warning_beep_pulse_time' was not declared
WARNING Found '${warning_beep_pause_time}' (see light->1->effects->0->strobe->colors->1->duration) which looks like a substitution, but 'warning_beep_pause_time' was not declared
WARNING Found '$zone5' (see output->0->pin->number) which looks like a substitution, but 'zone5' was not declared
Failed config
esphome: None
  name_add_mac_suffix: False
  project:
    project name needs to have a namespace.
    version: $project_version
  on_boot:
    priority: 800.0
    then:
      - text_sensor.template.publish:
          state: !lambda |-
thanks
All of the substitution variables are found here:
You will need to copy/paste the substitutions section into your own firmware config if you want to custom maintain it.
