I've got it working great, EXCEPT I wasn't able to use 'pin' in the configuration file.
konnected:
auth_token: auth_token
devices:
- id: xxxxxx
sensors:
- pin: 1
type: door
This didn't work, it caused the following error:
ERROR:homeassistant.config:Invalid config for [konnected]: not a valid value for dictionary value @ data['konnected']['devices'][0]['sensors'][1]['pin']. Got 3. (See /Users/ob1/.homeassistant/configuration.yaml, line 73). Please check the docs at https://home-assistant.io/components/konnected/ ERROR:homeassistant.setup:Setup failed for konnected: Invalid config.
So I changed 'pin' to 'zone' and it worked. FYI.
