[binary_sensors] is an invalid option for [konnected]
 I am trying to set up Konnected for the first time with Home Assistant.
YAML seems to be a nightmare to work with as it has very strict spacing and other requirements.
I have three Konnected boards, but am just trying to get one working as I can't get a config file to properly compile.
konnected:
 access_token: xxxx
 devices:
 - id: alllowercasefullmac
   binary_sensors:
 - zone: 1
   type: door
 - zone: 2
   type: door
 - zone: 3
   type: door
 - zone: 4
   type: window
 - zone: 5
   type: door
 - zone: 6
   type: window
I have also tried just using one zone
konnected:
 access_token: xxxx
 devices:
   binary_sensors:
 - zone: 1
   type: door
I get the following error
INFO (MainThread) [homeassistant.loader] Loaded konnected from homeassistant.components.konnected
2019-01-05 12:58:44 ERROR (MainThread) [homeassistant.config] Invalid config for [konnected]: [binary_sensors] is an invalid option for [konnected]. Check: konnected->konnected->binary_sensors. (See /home/homeassistant/.homeassistant/configuration.yaml, line 74). Please check the docs at https://home-assistant.io/components/konnected/
2019-01-05 12:58:44 ERROR (MainThread) [homeassistant.setup] Setup failed for konnected: Invalid config.
I am at a loss as to why binary_sensors is an invalid option. I have tried all kinds of different spacing to satisfy YAML but nothing is working.
Any help would be much appreciated.
Thanks.
