Hi All. I am a brand new Konnected user and have just setup my Alarm Panel Pro with Interface Kit to my Bosch Solution 6000.
I am attempting to reconfigure OUT1 to trigger the relay on the interface kit, in order to toggle a keyswitch to arm/disarm the Bosch alarm.
However, when I try to configure the board with the following:
switch:
- platform: gpio
name: Alarm Keyswitch
icon: mdi:shield-home
pin:
number: $out1
allow_other_uses: true
on_turn_on:
- delay: 500ms
- switch.turn_off: alarm_keyswitch
…I get this message when installing the updated configuration:
Failed config
output.gpio: [source /data/packages/8735b6a9/packages/warning-beep.yaml:9]
Pin 23 is used in multiple places.
platform: gpio
pin:
number: 23
allow_other_uses: False
mode:
output: True
input: False
open_drain: False
pullup: False
pulldown: False
inverted: False
I understand the issue, the fact that the OUT1 pin is being used for two different purposes, but I don’t know how to fix the issue. I tried setting allow_other_uses: true but because the buzzer use defined in the warning-beep.yaml file has that set to false it is not working.
Basically, I want to repurpose OUT1 for my own use and ignore the use as defined in the warning-beep.yaml file. How can I do that?
Hopefully this is an easy fix, just not obvious to me being brand new to ESPHome. Thanks in advance for any help!
