Working on my 2nd konnected setup.
It had 6 zones, nothing was labeled, and the keypad showed that Zone 5 was triggered.
So I've got it swapped out, and just did a direct mapping of the existing zones, and now know which zone goes to which door/window sensors. Except for the problematic Zone 5. No windows or doors triggered it. It's also triggering on/off without a clear cause. It's just a red/black wire (no aux), nor was it crimped together with anything else, and no resistors. Other than the door/window sensors, the system has the 4 keypad wires and the siren. No motions sensor or glass breaks, which i think require aux power. Would a garage door have a zone?
Its worth noting that there is one set of windows that don't trigger anything either. So my current assumption is they are Zone 5. I checked the window sensors, and don't see anything suspicious. Only problem is they just remain close and don't seem to have any correlation to when Zone 5 triggers on/off.
Anyway, could use some suggestions on how to debug this.
