Something doesn’t seem right. There isn’t a yellow LED on the Pro Panel. Maybe you’re seeing the green led?
It has a green power indicator LED (labeled “POWER”) which should be on steady whenever the device is powered.
It also has a blue status LED (labeled “STATUS”) which blinks on activity.
It also has two red alarm LEDs, that indicate if either of the alarm outputs are active.
We’d need more information about what platform you’re using. You can start troubleshooting by opening the device page in the browser or Konnected app and make sure that it’s online.
You were right, something was wrong. When I visually checked the wiring it looked OK. This morning I tested the buss connection I used for powering multiple devices and saw that it wasn’t 12V. I reconnected it and everything is good.
