Hello, I had to re set my v1.9 panel pro with Hubitat and am now seeing a warning in the log as below. Is there a remedy to stop the warning or to add this feature with interruptions to my system and setup?
[W][app:201]: Bootloader supports SRAM1 as IRAM (+40KB). Set sram1_as_iram: true under esp32 > framework > advanced
Also before the warning I did get errors as below **
dev:343**2026-05-06 07:47:44.441 AM
warn
[W][component:422]: mqtt cleared Warning flag
**dev:343**2026-05-06 07:47:27.313 AM
info
[I][mqtt:307]: Connecting
**dev:343**2026-05-06 07:47:27.278 AM
warn
[W][component:389]: mqtt set Warning flag: unspecified
**dev:343**2026-05-06 07:47:27.241 AM
warn
[W][mqtt:369]: Disconnected: TCP disconnected
**dev:343**2026-05-06 07:47:27.203 AM
error
[E][mqtt.idf:173]: Last esp-tls error: 0x8008, tls stack error: 0x0, socket errno: 0 (Success)
**dev:343**2026-05-06 07:47:27.167 AM
error
[E]
