I think I may have solved this. So for anyone else in the same situation here are the details.
The solution was in ESPHome. I had an instance of this running in it’s own Docker container, but I instead added the ESPHome add-in within HA. Following this article allowed me to adopt it.
I then edited the device’s ESPHome yaml with the following for each sensor.
I had the same problem with sirens. My device is Alarm Panel Pro version 1.8
In Europe, usually the sirens are wired the other way around. Instead of the siren to be silent when there’s no voltage, and make sound when it finds voltage, it makes sound when there’s no voltage and is silent when there’s voltage.
The reason for this is, if someone cuts the wires, to still make noise.
To fix this I had to add this to the default esphome configuration:
