Hi. I'm getting these errors every time I restart Home Assistant.
- I'm on a fresh install of HASSIO 0.107.6 running in Docker on an Ubuntu machine.
- Connected devices are on the latest firmware flashed last week.
- I setup Konnected through the UI as an integration
- I see my devices
2020-03-29 09:08:24 ERROR (MainThread) [homeassistant.config_entries] Error unloading entry Konnected Alarm Panel for binary_sensor
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 295, in async_unload
hass, self
File "/usr/src/homeassistant/homeassistant/components/binary_sensor/__init__.py", line 138, in async_unload_entry
return await hass.data[DOMAIN].async_unload_entry(entry)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 173, in async_unload_entry
raise ValueError("Config entry was never loaded!")
ValueError: Config entry was never loaded!
2020-03-29 09:08:24 ERROR (MainThread) [homeassistant.config_entries] Error unloading entry Konnected Alarm Panel for sensor
hass, self
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 64, in async_unload_entry
2020-03-29 09:08:24 ERROR (MainThread) [homeassistant.config_entries] Error unloading entry Konnected Alarm Panel for switch
hass, self
File "/usr/src/homeassistant/homeassistant/components/switch/__init__.py", line 78, in async_unload_entry
