Alarm Panel Pro using Home Assistant and the in-built alarm system.
When an automation uses the action: alarm_control_panel.alarm_trigger it does not instantly trigger the alarm system. Instead it goes into “Pending” for the duration of the entry timer and then triggers like an entry door would.
How do I make an automation trigger the alarm instantly?
Many thanks.
