Hi,
Has anyone had success with this board?
My in place alarm system just has two keypads and three motion sensors.
I have successfully brought the 3 motion sensors into Home Assistant.
From what I can find online and in the manual the owner left, there is no mention of programmable outputs. Can I use an empty zone to do this somehow?
There is also no mention of a key switch in my manual. In other manuals for similar panels online, I have seen mention of using the panic zone on panels like this.
My specific panel shows the attached.
So it says, “normally” Open, Panic. So maybe that indicates it can be changed?
Now I know in Konnected YouTube video for the interface panel, it says you can use any open zone. I have open zones, so I guess it would just come down to if my keypad has setting options for a key switch that the manual is not mentioning?
Any help would be greatly appreciated!
