A few questions about the Alarm Panel Add-on board's outputs:
- What are folks using the OUT terminal and OUT male header pins for?
- If I use the OUT terminal, may I still use the 6 input?
- The Identify the board page states that the OUT male header pin is "Dedicated OUT zone (same as #6)." Does same at #6 mean that the same signal will be sent out the OUT header pin and the OUT terminal simultaneously?
Thanks!
