Does anyone know if it would be possible to use a SS49E Hall Effect Sensor for an input to a zone and use this in home assistant? This would use the 5V and GND on the pro panel to provide VCC to the sensor, and the output from the sensor would provide 1-4V (or something like that) into a zone.
After some more research perhaps I should be using something like a KY-024 or an similar item like (49E Hall Sensor LM393 Linear Hall Effect Sensitivity Detection Module (Hall Sensor and Jumper Wire) by MUZHI https://www.amazon.com/dp/B09BJC64NM/ref=cm_sw_r_apan_glt_i_JF1Q8HGJWB8C5W5JKWT4) which provides a digital output similar to the DHT sensors?
