After a network change I am having all sorts of issues getting my Konnected V2 Interface system working again.
After resetting my Konnected boards (just reset not refreshing) and completely removing my docker installation of Homebridge (uninstall and delete folder but not remove Docker), there seems to be some residual configuration that is causing the issue. How can I completely wipe everything. I'm using Homebridge in Docker on a Synology NAS. I'm now on v1.1.0. Here is the error I get after the accessories are added.
[7/18/2021, 6:42:14 PM] [homebridge-konnected] This plugin generated a warning from the characteristic 'Security System Target State': characteristic value 0 is not contained in valid values array. See https://git.io/JtMGR for more info.
And another error later on after accessories are added:
(node:2320) UnhandledPromiseRejectionWarning: Error: Cannot add a bridged Accessory with the same UUID as another bridged Accessory: fba808a8-ac1a-4299-8771-78f39419ff5e
at Bridge.Accessory.addBridgedAccessory (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/src/lib/Accessory.ts:564:15)
at Bridge.Accessory.addBridgedAccessories (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/src/lib/Accessory.ts:593:12)
at BridgeService.handleRegisterPlatformAccessories (/usr/local/lib/node_modules/homebridge/src/bridgeService.ts:382:17)
at HomebridgeAPI.emit (events.js:375:28)
at HomebridgeAPI.registerPlatformAccessories (/usr/local/lib/node_modules/homebridge/src/api.ts:340:10)
at KonnectedHomebridgePlatform.registerAccessories (/homebridge/node_modules/homebridge-konnected/src/platform.ts:827:16)
at /homebridge/node_modules/homebridge-konnected/src/platform.ts:721:16
at Array.forEach (<anonymous>)
at KonnectedHomebridgePlatform.configureZones (/homebridge/node_modules/homebridge-konnected/src/platform.ts:546:26)
at KonnectedHomebridgePlatform.provisionPanel (/homebridge/node_modules/homebridge-konnected/src/platform.ts:496:42)
at /homebridge/node_modules/homebridge-konnected/src/platform.ts:355:26
at processTicksAndRejections (internal/process/task_queues.js:95:5)
(node:2320) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
The boards somehow showing they are connected with different API endpoints, and they periodically go through a strange boot loop pattern. I would really appreciate your help in figuring out how to resolve the issue. Thanks so much in advance.
