Ranger 9000 with 5 GE alarm key pads, 39 zones defined in keypad
I have a Ranger 9000 with 5 GE Keypads. The range has 8 zone terminals AUX DC, Keypad wiring.
In the key pad you see 39 zones for motion, fire, doors, windows . I connected the alarm pro running ESPhone integrated with Homeassistent. based on wiring I assume many of these zones defined in the GE alarm panel are cabled in series. Testing shows example I get a motion dected for example kitchen. I then go to a door and open which triggers a motion detection for kitchen. Window opening also triggeres a motion detection.
The alarm panel somehow only fault on individual sensors that are wired in series together ut is there way for Konnectd to do the same?
Does anyone know if konnected can distinguish between sensors in a loop. Or are they all just seen as a single sensor alert for a given zone? The GE alarm pad shows each of 39 zone sensors and will fault on a individual sensors window, motion etc even when on the same loop. I am not sure how it does that however.
