So I have the blaQ installed in between the opener and the smart wall control. I’m looking to add UniFi door access to control my door but not sure which output from the blaQ to the access hub I need to use. I need a trigger from the hub to the blaQ to open the door and something to tell the hub the doors open or closed
did you ever get this working? I’m trying this same configuration but can’t seem to get it to work
I did! I have the BlaQ in between the MyQ wall control & the door opener. Then I have one of the contacts on the BlaQ wired into the door hub minion the NC terminals. I have to set the trigger to 0.01 seconds.
