How to sound piezo buzzer when tripped using SmartThings and SharpTools
Now that ActionTiles is gone, I’ve setup SharpTools with SmartThings integration with my Konnected alarm panel. Everything working perfectly except one problem.
How do I configure SmartThings/SharpTools to sound the piezo buzzer when a device is tripped?
I have the piezo showing as a device in SmartThings and I can manually turn it “on” (sound it) and “off” (silence it). I’ve searched the net for solutions including ChatGPT but I cannot figure out how to do this.
Thanks in advance.
This is where SmartThings Routines come in.
It’s basically an automation builder with If … Then … style options. The If is when a door opens or whatever, and the Then is activating the buzzer.
Try setting up the Multi-output feature on your buzzer zones. This lets you create different beep patterns on the same physical output (each one shows up as a different momentary button or switch in SmartThings) and you can use Routines to make chimes or beeps or whatever in different conditions.
Yeah, I thought of this but there is a Boolean logic problem I don’t know how to solve. I need the logic to be something like:
If Armed AND (Garage Door Tripped OR Front Door Tripped OR Side Door Tripped) THEN Turn on Buzzer
Is that possible? I’m I missing something in SmartThings perhaps?
