Updating to the latest version of ESPHome (8.2) on Home Assistant I kept getting some error in regards to pre close warning and had to comment out that section in garage-door-cover-wired.yaml to make it work:
close_action:
# - button.press: pre_close_warning
# - delay: $garage_door_close_warning_duration
- button.press: garage_door_opener_button
Is there something in the configuration file I should be updating to get this right?
Here’s my current config file:
substitutions:
packages:
remote_package:
url: http://github.com/konnected-io/konnected-esphome
ref: master
files:
- packages/garage-door-esp8266-base.yaml
#- packages/garage-door-cover-wired-and-range.yaml
- packages/garage-door-cover-wired.yaml
- packages/garage-door-wired-sensor.yaml
- packages/vl53l0x-range-sensor.yaml
- packages/garage-door-opener-button.yaml
- packages/switch.yaml
- packages/warning-led.yaml
- packages/warning-beep.yaml
- packages/wifi.yaml
- packages/status-led.yaml
# DASHBOARD IMPORT
# Enables automatic discovery and upgrades via ESPHome Dashboard
# more: https://esphome.io/guides/getting_started_hassio.html
dashboard_import:
package_import_url: github://konnected-io/konnected-esphome/garage-door-esp8266.yaml@master
import_full_config: false
# WEB SERVER
# Enables the built-in web server for viewing the device state, internals and controls via web browser
# on the same local network as the device.
web_server:
include_internal: true
# LOGGER
# more: https://esphome.io/components/logger.html
logger:
esphome:
name_add_mac_suffix: false
binary_sensor:
- id: !extend garage_door_wired_sensor
name: GarageDoor Wired Sensor
internal: false
wifi:
ssid: !secret wifi_ssid
