Alarm panel fails update ESPHome 2026.6.3
The alarm panel will not update to ESPHome 2026.6.3. I get this error.
In file included from /data/cache/platformio/packages/toolchain-xtensa-esp-elf/xtensa-esp-elf/include/c++/14.2.0/bits/stl_pair.h:65,
                 from /data/cache/platformio/packages/toolchain-xtensa-esp-elf/xtensa-esp-elf/include/c++/14.2.0/bits/stl_algobase.h:64,
                 from /data/cache/platformio/packages/toolchain-xtensa-esp-elf/xtensa-esp-elf/include/c++/14.2.0/list:62,
                 from src/esphome/components/script/script.h:3,
                 from src/esphome/components/script/script.cpp:1:
/data/cache/platformio/packages/toolchain-xtensa-esp-elf/xtensa-esp-elf/include/c++/14.2.0/compare:1165:9: internal compiler error: Segmentation fault
 1165 |         requires __partially_ordered<_Tp, _Up> || __op_eq_lt_lt<_Tp, _Up>
0x17c3c63 internal_error(char const*, ...)
	???:0
0x84083b c_parse_file()
	???:0
0x9371cf c_common_parse_file()
	???:0
Please submit a full bug report, with preprocessed source (by using -freport-bug).
Please include the complete backtrace with any bug report.
See <https://gcc.gnu.org/bugs/> for instructions.
*** [.pioenvs/konnected-611a2c/src/esphome/components/script/script.cpp.o] Error 1
I have both the Alarm Panel Pro and the Garage Door controller, the error above was for the Garage door. Apologies for the confusion. I can’t seem to edit the title though.
In other news I ran the update today on both and they both ran successfully.
This looks like a local environment issue on whatever computer or machine you are using to compile the firmware, and not an issue with the Konnected device or firmware.
Yeah I was going to post an update. I had some issues with the 2026.6.4 release today and then with the HA 18.1 update. Working through all that, everything updated. So I agree, this was a false alarm on my part. My apologies.
