Ive been trying to locate information on how the add on board works... unboxing states no wired connection needed... Do both boards require a wifi connection? Or is there a magical connection that happens no one is mentioning?
You need to put a wifi module in the add-on board. Simply plug it into the power pigtail. Use the same instructions that were used for the main board to add it to your wireless network.
My Add -On Board was connected to wi-fi and initially recognized through SmartThings , but then i either accidentally removed it or connect was lost from Smartthings Smart App
The main board is still connected, configured and working but when I attempt to re-add the add on board through Add a Konnected Device it is not found.
I have attempted to reboot the device, press and hold the RST button and the blue light flashes a couple times but still nothing is being recognized through SmartThings. When I unplug and re-plugin the add in board, the blue light blinks a couple times and goes off, which the instructions also indicate that it is connected to wifi. What is the Flash button for on the add-on board, do I need to push this too?
How can I get SmartThings Konnected (Connect) Smart App to find the Add-in board when attempting to re-add it back in through Add a Konnected Device.
