Wire Harness instead of terminals (easy upgrades)
I basically created my own harness using some various parts but it would be nice to have a connector built-in that corresponds with the pinouts for each input and have a wire harness that just plugs into the Konnected board. It would need to be color-coded i.e (black/black stripe, orange/orange stripe, ...) for each zone.
You could spice all of the wires to the harness first and then just plug the harness into Konnected. It would also make upgrading to new boards easy.
Similar to a car stereo harness. (picture below)
Please do not implement this request on the core product. While this would make adding and removing a board easier, it would either drive up the cost (additional header) or clutter enclosures (replace terminals) in the normal case. I don’t want an extra 24 splices per board in my box. It’s much simpler/cleaner to just stick with terminals like the systems we would be replacing.
It’s possible, though I suspect unlikely, that there may be a small market for a quick disconnect harness that could be splices onto on one end and then wired into the terminals screws, however.
