Unable to Update for ESPHome 2024.2.1
Hi, I’ve been using my Garage Door Opener V2 for a few weeks now with the ESPHome firmware. However, it will not update wirelessly from 2023.12.9 to 2024.2.1 due to CMake not being able to locate both the C and CXX Compiler. Below is my YAML setup as well as error log. Any help would be much appreciated.
substitutions:
packages:
  gdov2_s: github://konnected-io/konnected-esphome/garage-door-GDOv2-S.yaml
esphome:
  name_add_mac_suffix: false
api:
  encryption:
    key: **************************
wifi:
  ssid: !secret wifi_ssid
Updating /config/esphome/garage-door-8cefe4.yaml
INFO ESPHome 2024.2.1
INFO Reading configuration /config/esphome/garage-door-8cefe4.yaml...
WARNING GPIO3 is a strapping PIN and should only be used for I/O with care.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
INFO Compiling app...
Processing garage-door-8cefe4 (board: esp32-s3-devkitc-1; framework: espidf; platform: platformio/espressif32@5.4.0)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
 - framework-espidf @ 3.40406.240122 (4.4.6)
 - tool-cmake @ 3.16.9
 - tool-ninja @ 1.10.2
 - toolchain-esp32ulp @ 2.35.0-20220830
 - toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
 - toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch5
Reading CMake configuration...
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
-- Configuring incomplete, errors occurred!
See also "/data/build/garage-door-8cefe4/.pioenvs/garage-door-8cefe4/CMakeFiles/CMakeOutput.log".
See also "/data/build/garage-door-8cefe4/.pioenvs/garage-door-8cefe4/CMakeFiles/CMakeError.log".
CMake Error at CMakeLists.txt:2 (include):
  include could not find load file:
    /data/cache/platformio/packages/framework-espidf/tools/cmake/project.cmake
CMake Error at CMakeLists.txt:3 (project):
  No CMAKE_C_COMPILER could be found.
  Tell CMake where to find the compiler by setting either the environment
  variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to
  the compiler, or to the compiler name if it is in the PATH.
  No CMAKE_CXX_COMPILER could be found.
  variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
  to the compiler, or to the compiler name if it is in the PATH.
========================== [FAILED] Took 8.59 seconds ==========================
===== [ERROR] /config/esphome/garage-door-8cefe4.yaml =====
======================== [SUMMARY] ========================
  - /config/esphome/garage-door-8cefe4.yaml: FAILED
