Finally, Success for me as well! But not after a world of pain...
I ended up having to systematically delete everything and start from scratch. The steps that worked for me were:
- Before doing ANYTHING - go into the Konnected smart app in the Smartthings mobile app, click on each board you have (I have two) and take screenshots of the pin mappings before you do anything. I did not do this, and it caused me a world of pain later when I had to remap all of the sensors again. I stupidly threw away the labels from the wires in the cabinet after I successfully installed Konnected years ago, so when I had to do the remapping, I ended up having to do trial and error by running around the house opening and closing doors and windows to see which sensors changed states!
- Go through the devices in My Home in the Smartthings mobile app (eg. Front Door, Living Room Windows) and delete all sensors that were connected through Konnected
- Delete both Konnected boards from the Konnected smart app in the Smartthings mobile app (I have two Konnected boards since I have more than 6 Zones)
- Take both boards off of the wiring bases, download the latest Firmware and File System files from the Konnected Github account (as described in an earlier post by Steven Lin - https://help.konnected.io/support/solutions/articles/32000023470-flashing-konnected-firmware-software) and flash both boards
- Reinstall only one of my two boards, power cycle it, then go through the Konnected smart app in the Smartthings mobile app to detect the newly connected Konnected board, then set up each zone from scratch.
- NOTE: It's important to do each board one at a time to make it easier to identify each sensor. Word of warning - if you no longer have all the wires in your wiring cabinet still identified (I labeled each set of wires with the name of the door/window/motion detector, etc when I first installed Konnected, but threw those labels away after the process), it's important to do each board one by one to make it easier to identify each sensor.
- Once I had everything remapped, everything is working once again
